3-Jaws indexing spacers 三爪、分割工具头 A.T.C.system 加工中心机刀库 Aluminum continuous melting & holding furnaces 连续溶解保温炉 Balancing equipment 平衡设备 Bayonet 卡口 Bearing fittings 轴承配件 Bearing processing equipment 轴承加工机 Bearings 轴承 Belt drive 带传动 Bending machines 弯曲机 Blades 刀片 Blades,saw 锯片 Bolts,screws & nuts 螺栓,螺帽及螺丝 Boring heads 搪孔头 Boring machines 镗床 Cable making tools 造线机 Casting,aluminium 铸铝 Casting,copper 铸铜 Casting,gray iron 铸灰口铁 Casting,malleable iron 可锻铸铁 Casting,other 其他铸造 Casting,steel 铸钢 Chain drive 链传动 Chain making tools 造链机 Chamfer machines 倒角机 Chucks 夹盘 Clamping/holding systems 夹具/支持系统 CNC bending presses 电脑数控弯折机 CNC boring machines 电脑数控镗床 CNC drilling machines 电脑数控钻床 CNC EDM wire-cutting machines 电脑数控电火花线切削机 CNC electric discharge machines 电脑数控电火花机 CNC engraving machines 电脑数控雕刻机 CNC grinding machines 电脑数控磨床 CNC lathes 电脑数控车床 CNC machine tool fittings 电脑数控机床配件 CNC milling machines 电脑数控铣床 CNC shearing machines 电脑数控剪切机 CNC toolings CNC刀杆 CNC wire-cutting machines 电脑数控线切削机 Conveying chains 输送链 Coolers 冷却机 Coupling 联轴器 Crimping tools 卷边工具 Cutters 刀具 Cutting-off machines 切断机 Diamond cutters 钻石刀具 Dicing saws 晶圆切割机 Die casting dies 压铸冲模 Die casting machines 压铸机 Dies-progressive 连续冲模 Disposable toolholder bits 舍弃式刀头 Drawing machines 拔丝机 Drilling machines 钻床 |
